Hdd nav upgrade
Tribbert
Houston, Tx
Hi Everyone. Hoping ya'll can shed some light on my current predicament. I ordered a 2013 Factory Nav Unit off Ebay and had it installed in my 2011 Tahoe with Bose. I had to purchase a 2012-2013 GM HDD Navigation Upgrade wiring harness (P/N GMFAKBFP ). I had everything installed with the addition of a Rydeen backup camera and DVD bypass. I went to River Oaks Audio here and Houston and they did the whole install without telling me I was going to have to have the unit re-prgrammed by the dealer. They initially said they could do it.
The problem lies in page 6 of the link at the bottom where you find the Programming Note: " IF RADIO IS NOT PRE-PROGRAMMED BY UNITED RADIO, RADIO MAY REQUIRE PROGRAMMING. VEHICLES WITH Y91/Y92 WILL REQUIRE PROGRAMMING FOR AUDIO TO WORK. IF RADIO REQUIRES PROGRAMMING IN VEHICLE WITH MODEL YEAR PRIOR TO 2012, YOU WILL NEED TO USE A 2012 VIN WHEN PROGRAMMING. YOU MAY ALSO NEED TO MAUALLY ENTER THE RPO CODES CORRESPONDING TO THE VEHICLE."
Anyways long story short, my Tahoe is a 2011 and the dealerships don't feel comfortable using a VIN when re-programming that isn't mine. It's very irritating because the wiring harness is a GM part and the random 2012 VIN will not be used in the actual re-learn. Has anyone modded their radio like this before? Will I just need to return my pre-owned unit for a pre-programmed unit? Anything will help at this point. I've been driving around for over a month with a dud of a radio showing "Locked."
http://www.installer.com/pdf/am-gmfakbfp.pdf
08grey
Look up Cps audio in Cali. Guys name is Greg. He has done all our radios pm me if you don't find it I should have his number. He is the man.
Tribbert
Tribbert
Houston, Tx
Thanks Grey. I had actually called him and left him a message right after the holidays and never heard anything in return. Definitely worth another shot. I would rather not just fork over $120 to the dealer for nothing, and I have been good about not taking it in to at least try. Did he do anything special for your setups?
08grey
He was probably away. Hit him up. He knows exactly what to do.
mohd33303
