headers, hi flo cats?
rippinitup
NY.
whats up guys i have an 03 yukon xl with a corsa catback exhaust and airraid intake. i was planning on doing headers before i get a blackbear tune.
i just dont know much about headers,long tube headers hi flo cats exc. can someone school me and also recommend on what i should go with? thanks!
Big Buttons
The SS Burb
South Texas
Get some longtubes (I have speed engineering) get a catted y pipe if you need to pass emissions.
If you are not going to use cats you will need Justin to tune out your 2 rear O2 sensors.
rippinitup
rippinitup
NY.
are there any longtube headers that are a direct fit no modification needed? i see theres plenty name brands also is there any thats the "best" or they all do the same job.
i most likely will keep cats on so was thinking to go with some hi flo cats. from the best of my knowledge.
Big Buttons
The SS Burb
South Texas
If you are 4wd all longtubes will need modification. None for 2wd.
If you keep cats the y pipe will need to have the cats welded in. unless you find a kit with them already.
rippinitup
rippinitup
NY.
my truck is awd, what type of modifications will it need to fit? any recommend long tubes with cats?
Big Buttons
The SS Burb
South Texas
you will need to trim around your front driveshaft. Just use a big hammer.
I don't know who or if anyone makes kits with cats in there.
Ridculous
Tulsa OK
Stainless steel works has a set of long tube headers with cattes I have them in my build. After a couple of hundred miles the driver side is rubbing on the steering column...slight nudging with a mallet takes care of that. I have a stock exhaust with aftermarket tips. This set up has passed the wife and 3 year old and 18 month test!
rippinitup
rippinitup
NY.
can someone link me to a set of headers with cats that i will need. having trouble finding what to go with
rippinitup
rippinitup
NY.
http://www.speedengineeringlsx.com/...gtube-headers-y-pipe-1999-2006-25-101125-1014
But wait for the next batch as they foobar'd the collectors on this batch.
Get the big boy 1 7/8"!
Best part s not they come with collector spikes!
And No change in price! So awesome! I might swap mine out for the new model!
thanks for the link, i see those dont have cats, id like to run cats. do you have any sound clip of yours? do you know any highflow cats thatll work with those headers?
pipehand903
