Headlamp Adjustment for Halogens?
Z71Jack
Hey guys...is there an adjustment screw to raise the the halogen headlamps in the LS? I noticed that mine are aimed way too low.
greenhornet
Ontario,Canada
Yes there is an adj. screw to left(passengers side) or right(drivers side) of the housing behind the rad saddle standing facing the engine. It is either a Phillips or hex screw. Set your vehicle back 25 ft. on a flat surface and measure down from a little mark in he center of the out side lens(middle of projector Lens) to the ground and transfer that to the wall and mark. the cut off line should be level or slightly lower than the line. Vehicle loaded in it;s normal running state.
2009TahoeLT
