Headlight Adjuster assistance
Breadman03
My son just got a 2005 XL and the headlight adjusters are shot. All of them Where can I find the proper parts? GM doesn’t carry them all from what I can tell and I’d like to avoid exchanging parts repeatedly trying to find the proper ones. It wouldn’t be too bad if the lights were aimed anywhere near properly, but they’re aimed like a drunk raccoon aimed them.
Thank you for any assistance.
Donal
Americus Georgia
Dorman lists several components for the vehicle. Check there. If you cannot find what you need, maybe post a photograph of the parts you need. Some racconns are ambidexerious and have trouble performing basic tasks.
Welcome to the Forum from NH.
Pics of the truck, please.
you can get some from the junkyard from any headlight for 00-06 pickups or suvs, the adjusters are all the same and the can be removed and replaced easily
the oem adjusters are usually just fine, but the aftermarket ones used on a aftermarket headlights are complete garbage usually just plastic inside but the oem ones have a metal sleeve., usually even if you have aftermarket lights you can swap oem adjusters in to replace them.
B
Breadman03
They're basically like these (screenshot from YouTube), but with Torx drive. I've seen a few that appear somewhat similar, but will look again. Thanks for the assists so far.
B
Breadman03
you have to pull the headlight out to replace the adjusters, those 2 L pins just twist open pull up and out
Thanks. We’re going to try the scrapyard again soon. Last week, they were all rusted to junk.
ya any adjuster from a 00-06 tahoe, yukon, suburban, sierra, silverado, avalanche will fit and work
the yukon/denali have a different headlight shape but the adjuster will fit, not sure on the escalades.
Nix409
