Headlight question
AH64Medic
South Carolina
Please be easy on me. Can someone explain or make a picture labeling the bulbs on the factory chevy headlights? To clarify, I was contemplating putting in an HID kit I took off my wife's 2012 Sonata (traded it in) and putting it in my wife's new Outback. But after finding it may be easier to drop the front bumper to install the new bulbs I decided to mess around with my suburban instead. I would like to do a mod like the hi4 so I got to looking at what I needed to do. Now I've only had to change the low beam bulbs since I've owned it. But after removing the lower headlight (marker?) housing I noticed the the inside bulbs were burned up and the plugs looked like they were fried. To clarify, the bottom housing has 3 bulbs as I can recall; the outer most has a little small bulb, then the middle is a turn signal and the inner bulbs (the DRL?). I replaced the inner bulbs and nothing happened. I checked the DRL fuse which is what I thought it might be and it was fine. So can anyone tell me specifically what each of the three bulbs are for and how I can fix the inner plugs? There are a few donors at the junkyard I can yank some plugs from if need be. Thank you for any help.
faroooooq73
