heated seat problem
hollywood_716
new york
Heated seat on driver side shuts right off. Pass side works great until you turn driver side on. Changed the elements and still does the same thing. Please help. Any ideas or solutions would be greatly appreciated. Thanks
Mildly
Washington
Did you change the seat and back elements or just one of them? There is a TSB on that! I will try to find it and let you know. I have the same issue in my 03 yukon slt.
hollywood_716
hollywood_716
new york
Changed back and bottom. Still the same. Hit the button and it will kick off after a couple of seconds. The passenger seat works great unless I turn driver side on when it kick off it shuts passenger off
---------- Post added at 07:00 PM ---------- Previous post was at 06:59 PM ----------
And the elements I took out didn't look like they were bad
a4edwin
ny
has anyone everfound the solution to this problem? mine does the same thing. and i've seen other posts about the same topic. never a solution though
04SS99Denali
NY
check the harness? make sure the harness isnt fried up and everythings plugged in
gclibby
