I am new to the site and this is my first post. I have a 1997 GMC Yukon, with front bucket seats. the driver side seat frame was cracked, welded and recracked so I decided to bone yard a pair. I found a set out of a 1999 Yukon. When I got home I found out that they had a few more options than my original ones. They are both 6 way power with lumbar and heated. The driver side plug just needs the power run for the heater. the passenger side needs a complete rewire. I was smart enough to get the plugs with about 4 inches of wire on them. I have figured out all but the yellow wire on the passenger side, I also need the pin out for the bulkhead connector for both the 97 and 99. My goal is to make my mistake look like it came from the factor. I want to run the wires like GM did on the 99 Yukon for this set of options.
Thank you for you help.
