Heated Seats not working?
triangle12
First, i'm new to the forum so i hope i'm posting this in the right place. I have an 01 Yukon XL with both driver and passenger seats that don't heat up. Indicator lights come on when you push the button on the door but neither will heat up. any suggestions on where to start looking? i did have new leather installed during the summer and now is the first time i have attempted to use the heat. Maybe a wire came loose during install??
ajaxnxs
Rockwall,TX
Start checking the fuses.too and the wiring in the seats.
Sent from my Motorola ATRIX using Tapatalk
T
triangle12
heated seat
will do, Thanks!
---------- Post added at 05:19 PM ---------- Previous post was at 04:05 PM ----------
it was a bad fuse. i should have looked at the fuses first. thanks for the help!! now the only thing left to fix is the rear heat/ac
Rivieraracing
will do, Thanks!
What fuse was burnt up and where was it located?
cjprod0684
