Heated Seats
tna0066
Both of my heated seats stopped working at the same time. I checked my fuse, which is oddly the same as an ignition fuse...it was fine. Is there a relay or something i should be looking for? When i press the buttons on both drivers and passenger side, nothing happens, no lights or anything come on.
quattrotman
There is a module under the passenger seat that controls the seat heaters. It is attached to the seat (not the floor) and is closer to the center console side. It is common that one of the contacts on the connector to the module is not making good contact. If you unplug the connector, one of the connectors is slightly burnt. That's the one that is a problem. Usually you can bend the metal blade a bit so it makes a better contact. If it's really bad, you need to change the whole connector. Do a search on it, you will find several threads on it and some with pics.
ericherm1
