Heater A/C controls
JcKinney
Albion, Michigan
My yukon is a '95. A while back, faulty hood took out my windshield and cracked my dash and I had to take it into the shop and have it replaced. I've heard before that '95 is only compatible with '95 in the dash electrical, is this true? The body shop fried my controls, but won't own up to it so I need to find a new assembly before winter. Am I limited to '95 or will other years work?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
unfortunate later 94 and earlier are different system and the 96-newer did not have a wiring harness attached to unit like 95 did so only a 95 will work but that does not mean you are limited to just Tahoe. Look for used Suburbans and trucks of they same year.
JcKinney
JcKinney
Albion, Michigan
Thanks, I'll be hittin the yards today. I had a lead on one from a 95 truck, but no rear defroster control on that one :(
JcKinney
JcKinney
Albion, Michigan
After test fitting a replacement, I found I still had the same problem. Started looking around under the dash and apparently, the shop that fixed the truck decided not to re-install brackets that open/close my vents :mad:
lhrandall
How easy it it to replace the blower motor resistor on my 1996 Tahoe?
SunlitComet
OBS Jedi-Do Good
:welcome:
Remove your glove box and it should be right next to the relay on left.
Remove or Disconnect
  1. Negative battery cable.
  2. Roll instrument panel back.
  3. Plenum tray.
  4. Electrical connectors, as necessary.
  5. Screws.
  6. Blower motor resistor.
Install or Connect
  1. Blower motor resistor.
  2. Tighten screws to 1.9 Nm (17 lb in) .
  3. Electrical connectors, as necessary.
  4. Plenum tray.
  5. Roll instrument panel forward.
  6. Negative battery cable.
    • Check circuit operation.
pistolpetem9
