I've been having a problem with the temperature control sticking. Sometimes the driverside will be blowing cold air with the heat turned on and then the passenger side will blow heat with the AC turned on. The rear air doesn't get hot at all. Is there a door or something that could be sticking? Usually if I turn off the engine and restart it, everything starts working until I adjust the temperature again. Its an 2004 Tahoe. I appreciate any help I can get!
