Tahoe 2001
The fan first dropped the fifth speed, then a lower and then it stopped completely.
I removed the resistor, it eas corroded so much that it causwd overheating and melted the connector. Had to break it to remove it.
I’m in Sweden and the resistors are a tad pricey, around $100, so I got a used from a scrap yard including the broken connector.
The ”new” used is also corroded. Is it sensible to paint it with laquer, or should I use grease or what?
