KMeloney
- Joined
- May 2, 2009
- Posts
- 3,157
- Reaction score
- 477
Hey all,
Here's the deal: Started to get a fast-blink on my LEFT LED tail lately. At this point, it fast-blinks every time I use the left signal. I swapped my Denali tails in in the meantime -- and I STILL got the fast blink (left only) with them in.
Upon swapping my LEDs back in, I've noticed that the reverse light does not light in the left housing. Also, when I unlock the vehicle with the remote, where the brake lights and reverse light would normally illuminate, NO LIGHTS in the left LED tail light. Oddly enough, the brake lights illuminate under normal brake application, and the standard (non-braking conditions) lights work under normal circumstances, too.
So, in a nutshell, regarding the left LED tail lighting:
- No reverse light, ever
- tail lights light fine when lights are on
- Brake lights light fine when brake is pressed
- NO lights light when brake/reverse lights should come on upon remote unlocking
- Lights light, but blink fast, when left turn signal used
What has me a little concerned is that I got a fast blink with the stock Denali housings in there. (What I didn't do is diagnose the circumstances of the range of lighting of the Denali lights...)
Does this sound like just the reverse bulb is out (and maybe out on the Denali light, too), or does it sound like a bigger [wiring] problem?
Thanks!
-Kirk
Thanks!
-Kirk
