HELP! Lost ring!
morgan.a.badley
I was driving my 2010 Chevy Tahoe LT, and while talking with my hands, my ring flew off my hand toward the passenger seat. I have dug around everywhere, stuck my hand under the seat, moved the seat, in between the seat and the middle console, and I can't see it. Is there a way for me to either remove the seat temporarily and locate it, or is there a nook or crany i have possibly overlooked? I don't want to buy another ring, (sentimental value) so if anyone has an suggestions, I'd be really thankful. (It's 100% sterling silver if that makes any difference what so ever).
Modded
That Guy
Make sure you check under the passenger side plastic seat rail covers while you are searching.
They're are four plastic covers (2 in the front of the seat, 2 in the back) that cover the bolts that hold in the seats. Pop them off and see if it's hiding under them. Also check in the passenger side door panel.
GM Customer Service
Michigan
Morgan.a.badley,
I would check the plastic covers and door as modded stated. If you want to remove the seats then I would talk to the dealership and they will be able to do this for you.
Breanne
GM Customer Service
jeffyrc
Bow Tie For Life
SoCal
well i gotta ask, was the window open?
---------- Post added at 07:05 AM ---------- Previous post was at 07:04 AM ----------
Modded that's were I always find my stuff at
not to thread jack but i love the train horn. where can i get me one of those?
yates ™
Resident Apple hater
Iowa
I would get a magnet and fish around with that.
edgaranah1
Corona California
Yeah a magnet will def help a bit. Like modded said pop those caps up. There's enough room under the carpet where ur ring could be sitting.
Sent from my BlackBerry 8530 using Tapatalk
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
or you can loosen the seat bolt or remove them, then tilt the seat back and forth and look or it that way. Have you checked between the seat cushin and seat back? Might find some loose change in there too
etreanor
