Help me get the driver door panel off
wade
Trying to get my driver door inner panel off my 03 Denali.
I found a few screws, took em out. Do i Slide it up? or pull out? does the switch panel need to come off? cause its a *****
MASS-HOE'Z71
Mass
2 screws;bottom of door and behind the interior non moving handle. Pull out plastic piece from opening handle and piece that gives access to mirrors. Pull door panel upwards on it enough to clear big white "clips" and you should have enough access to disconnect the plugs under the button panel. You have to pop the manual lock piece (slides and reveals orange if unlocked)too if i remember. Its a pain in the ass until you figure out where everything is, it'll be alot easier next time
W
wade
yea i got the panels and screws off, but still it wont budge, i guess i have to pull HARD upwards
vatahoelt
NoVa
yeah, you'll just have to give it a little bit extra and pull up once you remove the 2 screws.
casper
Grove, Ok
How i got mine off was i grabbed from the bottom and jerked up it came off the top and then i just popped it out of the plastic holders it was in by pulling out one at a time.. came off easy only had to replace two of the little plastic pieces
YukontGetThis
Banned
some guy posted a body shop forum link on here on all GM door panels for different years..
