Help me understand how the HEAT system works
TahoeJim
SE Ohio
Heat in the Tahoe's been luke-warm / fair at best all winter. Temp gauge also never climbs above the line that would be ~140 degrees on the factory cluster.
One school of thought is that the thermostat in the truck is either stuck partially open or it's maybe way too cold of a thermostat...160 degrees or similar. Cheap and easy enough to replace, I'm just going to do it.
So I'm staring at the heater control valve which sits between the firewall and water pump / engine. It has a solenoid with mechanical linkage, when a vacuum is applied it opens the internal gate to allow coolant into the heater core.
Does this valve open progressively as more vacuum is applied, as the dash control is dialed over towards max heat? Or is it all or nothing and the "blend door" down under the dash actually controls the heat felt in the cabin?
Could it be that whatever is applying vacuum to that solenoid isn't applying enough to open it fully? Or maybe the solenoid itself isn't opening, it's old/hanging up internally....and not allowing a full flow of coolant to enter the heater core?
Blend door....what exactly does it do and how does it work? Blending outside air in with the heat coming off the core or ?
And lastly the heater core itself....if it's partially clogged, I was wondering about just disconnecting the hoses at the heater control valve and trying to flush the core out directly. I've heard vinegar and water do a good job of cleaning out scale and muck. Or maybe buy some of the heavy duty cleaners they sell at Napa?
Looking for input or better yet, diagrams out of a shop manual that might make life easier.
ravingmadman
Chief Knuckle Buster
Greater Seattle
Wow. Too technical dude, you make my head hurt. I'd swap the thermostat, and the fan clutch (better yet, go with e-fans and do one job to kill two problems) and call it a day. If that doesn't do it, trying to hunt down all the linkages to the trap doors in the heating system really sucks.
TahoeJim
TahoeJim
SE Ohio
New 190 thermostat, new heater control valve and a good flush has solved the issue. Thermostat was stuck partially open, heater control valve solenoid wasn't diverting the coolant flow as it should and what came out after the flush looked like hell.
Nice hot air when the heat is dialed in and a temp gauge that actually shows the truck coming up to proper temperature. Not a bad fix.
Well Worn Chevy
