YanaCakes
- Joined
- Aug 4, 2024
- Posts
- 21
- Reaction score
- 4
I have a 2012 Hoe with a 3.5" RC lift. The truck is 4WD without air suspension. The sway bar bracket rusted off the frame (the frame looks good underneath bracket). I am going to get a new bracket welded (unless you know of other options) and replace the sway bar links. One of my axles is also spewing grease and needs to be replaced. Can I go with OEM options or should I do extended links and/or axles? Also, should I replace the sway bar? I cannot get a look at it because the truck is undercoated.
