screamin chicken
I'll start with this, GM is getting a bad taste in my mouth, I may have to go back to FORD. This all started with my 2000 WS6 that's a garage queen, with 40.110 miles, I'm the only owner, while in Warranty they would not fix the t top pillar , the ones that do not know the paint has bubbles that leak, the door panels cracked, dash did also, all under warranty, GM wouldn't fix any of this under warranty. Now fast forward to my 2007 Yukon XL while under warranty GM again would not replace my cracked dash, my leaking sunroof , it's not the drain holes, they replaced it before now it need a new seal, and I have a annoying rattles in the headliner now, my remote start doesn't work i assume because the code for the gas filler neck, my CD doesn't eject, all while under warranty, and now my mirrors are acting up, and my drivers seat will stop working at times.....
So i took it to my local dealer after getting to talk to gm and they want me to pay 700 dollars on a 53,000 Yukon that's 6 yrs old. this is what i need, sunroof gasket ( is this the plastic part that flaps up when its open , if so the jerk that replaced my sunroof never installed it back, it needs a driver seat module, and a module in the door for the mirrors, where can i get these parts so i can fix my 53,000 6 year Yukon on my own.... Thank you
And Thanks to GM for being there for you Customers the ones that keep you going, I am in the market but i will look into Ford, and IF I DO Stay faithful I will keep a LOG book this time and I WILL be at the DEALER for every little thing as POSSIBLE and i WILL NOT let up.....
