Help please
LT97
So I'm the owner of a new 97 Tahoe. I was driving it back from where I bought it from when about 100 miles in it kinda stalled for a sec cruise went out and radio and power windows quit working. I checked all the fuses and non are blown. The instrument lights on the dash work but not auxiliary for the Ac controls and such any ideas?
ISU-152
Does it start still?
I'd just guess a new battery and alternator. Truck probably sat for a while before you bought it
L
LT97
Sta
Starts and drives fine idles fine that's what's baffling done lights work head and tail hazards etc..
ISU-152
Sta
Check all the wires and battery for corrosion. Quick wipe with some sand paper
L
LT97
Could it be a faulty ignition switch that gave out noticed the wipers don't work either
L
LT97
What works it starts and runs power locks running lights head tail turn hazards. Wipers don't work Ac/heat blower motor doesn't work radio doesn't come on power windows don't work 4x4 blinks engage on 4hi 4low
Jimmy John
My Impala does similar things and I changed the ignition switch and it went a way for a few months and still comes back once in a while. Seems to be worse in cold temperatures. I think it may actually be a problem with making a good connection at the connector going to the ignition switch you might try pulling it off and reseating it.
QUYHMK
