HELP: Violent steering wheel shake
JVMet730
2001 Tahoe
250k miles
New wheels and tires
Like title says I get a violent steering shake. The shake was always there and recently bought new wheels (oem 20s) and new tires, perfect mount and balance and I was certain it wasnt a tire or alignment issue. Well since the swap the shaking is getting worse. It happens at 50-55 MPH and only when the steering is in a straight path and line. If im making and sort of turn it does not do it. Once I get around 60 or so it stops and is fine and same with under 50-60 mph. Any suggestions appreciated it's driving me nuts. It's so bad the whole truck shakes and when I say the steering wheel shakes and jerks around it's pretty extreme where I don't even want to drive it. Thanks in advance.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Inspect the entire front suspension and entire steering linkage. Make sure to jack under the lower ball joint as close to d of lower control arm, close to tire, as possible. Get the tire off the ground about 1-2 inches and then use a long pry bar under the tire at 6 o'clock and lift up and release and check for ball joint play, upper and lower. Grab tire at 3-9 o'clock and 12-6 o'clock and check for wheel bearing play. Check looseness a the tie rods and idler/pitman arms. Check steering shaft.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Inspect the entire front suspension and entire steering linkage. Make sure to jack under the lower ball joint as close to d of lower control arm, close to tire, as possible. Get the tire off the ground about 1-2 inches and then use a long pry bar under the tire at 6 o'clock and lift up and release and check for ball joint play, upper and lower. Grab tire at 3-9 o'clock and 12-6 o'clock and check for wheel bearing play. Check looseness at the tie rods and idler/pitman arms. Check steering shaft.
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
I agree, shakedown the front end focusing on wheel bearings, tie-rods and ball-joints. If 4WD also look at your front driveline u-joints for play.
ezmoney1981
