Hello, I need the rubber, or maybe silicone, piece that is fitted to the bottom of the purge valve in my 2004 Tahoe 5.3L (gasoline) SUV. The valve itself is part number 12581282, but the gasket (or whatever it's called) is separate. These purge valves were used in many model makes and years with the 5.3L (and other) motors. Anyone able to get this part number? Or does anyone know of exploded parts diagrams that are available on the web? Much thanks!!
The part can clearly be seen in the following youtube video:
Can see the part starting at 2:57 and can see it being removed and swapped starting at 3:11.
Edit: Also in this video, starting at 49 seconds (even better view of it being removed and swapped):
