HID ballast
Mr.Jack
Norway
I have just installed HID in my new foglights. (Smoke lense and 8000K HID)
But should I wrap that ballast in something? Or should I just leave it as it is?
I am thinking about dirt getting into that ballast or connections.
Haven’t checked if those ballast do get hot though.
What do you think?
Jac07
Springfield mo
I think your fine I have mine right behind my grill in my truck so it catches all kinda of stuff. Your ballast will probably get warm but not enough to do anything.
Mr.Jack
Mr.Jack
Norway
So no need to wrap it up?
Jac07
Springfield mo
I would say no. I have installed a lot of kits and never wrapped any of them. Never had any problems with them.
Mr.Jack
Mr.Jack
Norway
Already having problems with the right one. It only turns on every second time.
The old one works just fine when connecting them. Just the HID one causing problems.
I have no clue what is going on.
Do you?
CustomTahoe01
i thought the same thing when i first got my hids. but the connections have weatherproof sealings on them, so make sure you put the connectors in all the way to ensure a tight weatherproof seal.
DenaliAK
Colder than you
Alaska
As for protecting the ballast from dirt/debris/water, it all depends on the ballast. Many, if not most, are built to take a beating and are water-tight, but some of them aren't. I'd check the specs on the particular type you have.
humbertoltx
