HID Kit
LAYkon
Was wondering if anyone has heard of or has any info on the fallowing: http://www.ddmtuning.com/
Was debating on weather or not I should install some and if so any suggestion on which ones would be helpfull, Thanks.
Speck
Olympia, WA
Read the above thread by Soulsea on lighting.... Any PNP kit is not worth your time or money. The output is garbage and you will just blind oncoming cars. I made the same mistake and had a PNP kit for almost two years before getting a better idea of "good" lighting. Also check out HID Planet for a vast wealth of information on the subject. I finally had a projector retrofit build done for my 08 Denali and I could not be any happier with the results and light output. I hope this helps!
Joe
AZSCTACO
Phoenix, AZ
As for HID kits.....I've used DDM's HID kits for about 5 years. Surprisingly a very good kit for the money. Have had zero issues with them. If you are going to keep the factory lights with the HID kit, adjust the headlights down a little bit to avoid blinding oncoming traffic. I eventually went the retrofit route as well and it's 1000% better. But I understand if you don't have the $$ to drop on a retrofit. Good luck
L
LAYkon
So, after watching a video on the subject retrofitting a headlamp is nothing more than a hybrid or your stock lamp and a foglight? So you kindly force open your housing and cut out a place for your foglight while mounting it in place and putting your housing back together? I mean, in a nut shell that's the idea?
Speck
Olympia, WA
In the most basic form, yes. There are projectors and HID Harnesses and igniters that you can pick up for fairly cheap. Without getting into the OEM product or bigger builds, you can get a basic with parts for under $300, and then you're just out time for the build if you're willing to try it yourself. You'll pay a little more obviously if you choose to have someone build it for you.
Joe
L
LAYkon
This guy pretty much breaks it down step by step and has, IMO, a pretty damn good system of doing so. However, the alignment part seems a long and tedious, not looking forward to that.
Speck
Olympia, WA
It may be long and tedious, but oh so worth it in the end... Believe me! :happy160:
Joe
extremetint
http://www.putco.com/products.cfm?a...Category=2D6754BD-9BE8-C408-AE66-FD8037D1078D
This is what i run in mine you have to use the new cooling ribbon style nothing else will fit behind the low beams
L
LAYkon
Purchased a set of OEM Lights off ebay for a decent price going to try my luck on some Retros.
tahoe_highcountry
