Hid-projector Q
Drok
Cold place in the north
(Top of the light beam above the purple line, the laft side is worse)
Is the light supposed to have a blackhole like spot, while driving its almost impossible to see past that point. Idk if i alined them right or what? How would regular h1 bulbs work?
Speck
Olympia, WA
Are you referring to the "cut off point" or the change in height of the cut line? If you're referring to the dark space above the cut off line, that is normal for all projector HID's to my knowledge. Just make sure you aim them correctly (should be from ground to center of your projector lense, then go out to 100' and should be about 1" drop in beam height from ground to top of beam where black cut off is) that will prevent your lights from "hot spotting" and blinding oncoming traffic and vehicles in front of you with their mirrors. I hope that helps, Serge used to be THE go to person for info on this, but I don't think he is on here much anymore. @NathanJax would you have any more info?
Joe
Speck
Olympia, WA
Yeah, 25' is way too close... You could do 50' and do 1/2" drop... That could help.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Well, that line is correct and suppose to just be dark above that line. That line should also be at a certain distance up from a certain distance away.
It's suppose to more of a fine line, but that's just because of the projector & bulb you're using
My old projectors...
inmypassatlife
Should be measured at 25', best thing to do is find a common sedan, like a neighbors and at 25' aim them at just below the trunk deck, that way they will fall under the side mirrors.
Drok
Drok
I have these. Would different hid bulbs make a difference with the line thickness?
Im definitely not used to this set up haha
Drok
Drok
They hit the trunk line of most cars i drive behind at 15ish feet. Its got to be the line thickness and not being use to them thats got me all confused i guess ha..
inmypassatlife
Easiest and non professional way of measuring is if oyu are going down your street the left lower cutoff line should not go onto the dirvers seat of the parked car you are approaching at 25ft and the right cutoff should not go above the trunk at the same 25' distance.
DogBoss
