EzMac, where did you get everything and do you have a link or idea where I could find instructions to do this? I have used the search feature but have not found really good step by step instructions. Thanks.
Quick rundown:
I won't cover how to remove and install the headlights, you should be able to find detailed instructions for that.
- Open Depo headlights using either an oven or heat gun. Google for oven directions.
- Remove low beam bulb.
- Remove bulb cover, looks like a metallic cup in front of where the bulb is. One Phillips screw.
- Dremel down the post where the screw inserts into the reflector to make it flat so the projector fits flush. If you get the new Morimoto Mini H1 7.0, the stem should be long enough and no further modification is needed. If you want to use the solenoid high beams. Make a hole for the wires.
- Insert projector with one silicon washer. Feed solenoid wire. Tighten down lock washer.
- Wire up HID harness, ballasts, wiring and bulbs.
- Test mount headlamps and adjust rotational alignment, make sure cut off is level.
- Disconnect. Remove headlamp. Reheat and replace lens.
- Reinstall, wire in parallel high beam to solenoid. Attach other wires and remount.
- Find a flat wall and adjust beam height.
Very brief write up... Let me know if you need more details!
