In the middle of a front brake job on my hoe. Opened the package, pulled off the old pads, discovered that the old inner pads have a different bracket on them that clips into the inside edge of the piston. The new ones have a bracket that is removable, but is obviously not for this application. The new inner fits (with the bracket removed) and is in every respect the same dimensions as the old one, it just doesn't have the clip that fastens into the piston. Is this correct, are they intended to be fitted without that clip?
