How can I achieve this look?
crunk
I have an 03 Suburban LT 4x4 (NOT Z-71) and am love with this look. What size tires do you think these are? 35s?
Would keys + rear spacers be able to fit this?
AppocAlexx
Darth Appocalexx
Abilene TX
yes, at least a 6" lift, wheels look like 20s and tires are either 35s or 305.60s possibly, maybeee 305.70s. There is not much sidewall there but that is the look I would be going for when I get my 4" or 6" lift on.
AppocAlexx
Darth Appocalexx
Abilene TX
dang didn't notice this until a few more looks but does his rear end look a bit pushed forward or is it the angle of the pic taken?
01Konvict
Boats n Hoes
Raleigh/SML
Yep pushed forward as most kits do not relocate track bars down or back. Just big ass spring spacer to achiever lift. Need to research good lots before ordering
crunk
crunk
Thanks for the replies guys. I didn't realize this burban had that much lift but 6" makes sense considering those are probably 35's
mizzouguy
Lake of the Ozarks, MO
My friend put a long arm kit on his jk wrangler, it was a rough country. Came with adjustable track bars, adjustable trailing arms upper and lower front and back, spring alignment shims, etc. They may make something for the gmt800.
EDIT: http://www.roughcountry.com/gm-suspension-lift-kit-279n2.html
Comes with relocation brackets for everything, seems like it would work well.
01Konvict
Boats n Hoes
Raleigh/SML
Is there a kit that addresses that?
Yes, need to special order pro comp brackets from summit racing. Part number 90-1785 and 90-1790. Then need to read these instructions to locate various bolts and nuts from Home Depot or lowes to mount them on the burb. Look at pages 15-17 for rear end steps and bolts.
http://www.procompusa.com/aux_incl/pdf.ashx?pdf=51021B_K5072B_INST.pdf&line=EXP
No that kit does nothing for the rear axle swing forward in fender well. Still need pro comp parts listed above to center.
gbc60
