How hot/cool should ventilated seats feel?
LurkingLuke
WA
I'm not certain how well my heated and ventilated seats are working. Hot or cold, when I crank the settingto max (3/3), I can barely feel the effects. Something is working, but not a ton more than the placebo effect would be expected to.
HEAT: unlike some cars I've had, the seat in my Denali never feels "hot", as in, "I should lower this to setting 1 or 2." Should my seat be cranking out the heat?
COLD: I can't hear a fan going or feel any breeze. Should it be this subtle when working properly?
Fefanatic
The heated seats in my '11 will burn you out on 3. I have to set to two or one to be comfortable.
I cannot help you on the cooling side of the question, as my 2007 does not have that feature. But, on the heating side, as @Fefanatic stated above, the heating side gets HOT. In the cold weather, I often start the heating side to full heat position 3, and after a few minutes, I suddenly realize that my a** is on fire, and I need to turn the heat position down to 2 or 1.
PPV_2018
U.S.A.
On my 2003 SILVERADO the heated seats on MAX will have you sweating bullets after 20 minutes, even if it’s icicle freezing outside
I don’t own a vehicle with cooled seats, but any vehicle I’ve ridden in or driven with the feature is noticeably pleasing on max, regardless of how hot it was outside (get’s real hot where I am at).. so, bottom line, these features on max setting should be definitely noticeable.
nwalk7800
