How much to bend Autoride Rod 15 denali
RollinPresidential
Does anyone have pics on how much they are bending their autoride rods? I put a 2" rear drop (coils/shock extenders). Any help would be great. I see plenty of posts on people bending them but none I can find on how much.
73Vetteman
Autoride rod adjustment
Instructions included with Belletech lowering kit suggest 3" center to center assembled length for the replacement rods that are included in their kit.
I measured stock size at 3 9/16" c/c.
So they suggest 9/16" shorter rod for their 3" 34324 drop kit or 3/16" shorter per inch of drop.
Maybe 3 3/16" center to center for a starting point on a 2" drop?
08grey
Get the 3" screw Tony suggests and put the caps on. Cut just the head off then see how you like it from there. I think I settled on 2 3/4 long on the rod before the caps we're screwed on.
73Vetteman
Threaded Rods for Adjustability
You can make your own adjustable rods. If you can't find a 3" bolt just buy a length of threaded rod at your local hardware store or hobby shop and screw the caps from your stock rod onto it. The caps require a pretty hard pull to remove from the stock rods but do pop off. The thread size is 10-24. I measured the length of the stock rod at 3" and the length of the rods in the kit at 2.5". The beauty of the threaded rods is that you can cut off whatever length you need and adjust them by screwing the caps up or down on the threaded rod to suit your needs.
Keep your original rods if you ever want to restore the original suspension.
LekGMC
@RollinPresidential This is the size screw you will need. Like other guys said, you can just cut the head off the screw. I have mine set at 3 1/8" from center to center on the rods. It's right in the range of 3"-3 1/4" it's easy enough to play with and see where you like it. It's amazing how small 1/8" adjustments to the length of the rod, make the truck sit 1/4"-1/2" higher or lower. To me, there is a sweet spot where you get around the height you want AND the ride feels good.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
I've been using the 10x 24 3 inch long machine screws and include them with my custom kit for.a few.years now. Yiu can cut them down if needed but do it in small segments
Ykn11Cg
