Not trying to take the place of Bowtie, but wanted to hopefully answer the cliff-hanger question...
Yes, you can re-use the FI setup on the HT383E (just switch the top-end over to the 383)...and your factory computer will allow it to run. However, you'll need a custom tune to get the most out of it. If you choose to stay with the factory spider, max power will be limited by the fueling capabilities of the spider/injectors - which is why many opt for the carb, ram jet, or marine intake setups (you can upgrade the injectors since they are external).
