Hurting my girl?????
crows feet
Elberton Georgia
I am running my 95 yukon with out a thermo,running around 110,just enough heat to get frost of windows,it a5.7 tb.288.641 2 door 4x4 but want to make sure am not hurting engine, thnaks
oldsalt
You may not be "hurting" your engine but you should have a thermostat in it.
Your engine was designed to run at a specific operating temperature. (193-198)
Your mileage will be much better as your computer makes adjustments based on readings it gets from the engine. If your engine runs cool the computer will richen up the mixture to try to get it up to the correct operating temp.
Am I wrong here guys?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Put a new one back in. Not only would you get more heat for defrosting but your engine will not run in open loop all the time dumping more gas than needed. Why take it out in the first place? engine works better and cleaner at 190-200 range. It would also eventually where out your converters. Would not pass a smog test probably as well.
Jaycenk
Florida
Stick a piece of card boad in front of the radiator on the driver side untill you get one and have time to put it in. block off about 1/3 of the radiator. This will help the temp stay up. Had a work truck that had a bad thermo 7 winters ago and did this for a month untill I could have it down for a day. Just don't run the piss out of it. It will hurt the plugs a bit and run a bit rich with out it. Have to be carfull not to do it too long so not to clog a cat up.
Administrator
As cheap are tstats are just get a new one and stick it in there. You're motor will run much better with one and they are cheap and easy to put in!
black95
Freeport,NY
no excuses the 95 is rediculously easy , and prolly costs about 15 bucks for a stant 195 degree and the gasket
retorq
Kingman AZ
No gasket on the 95, it uses the old o ring.
There are a few threads on the internet saying if you run it as cool as you are you are damaging the engine. Not only is it in closed loop mode all the time like was already said but the oil never heats up enough to remove water and condensation from it.
C
crows feet
Elberton Georgia
Thanks alot guys for info,have learned alot,,,reason its out. is runs hot if put one in,tried 3 had a180 in. after doing a intake gasket replace. has run hot,new one from chevy place was a 210 but run hot so found raditor leak so replaced it,put thermo back in run hot again.its got to be wrong intake gasket,,onley thing i can figure.but at time funds are tight be few weeks before can redo with one from chevy place off my vin,when replaced did up grade to rubber on front and back insted of silocone,and yes i do get all the air out of system,no my hose dont suck in on it self....but gonga go back to oem hose...thnaks
CrashDavis
