HVAC Fan is eratic
beav626
Pretty Girls in your city for night
Usa
it works and blows cold air but fan speed does not match what I choose on the Auto climate control unit.
If I put it to max fan speed I get very low air flow. If I put it in auto mode it shows full speed ion fan but the fan is putting out low speed.
Sometimes when I turn off the truck the fan keeps blowing.
is my blower motor going out, or my HVAC controls?
recently my blower motor was squeaking at me, so I took it out and lubed it. it is quiet but acting crazy.
rv8tor
I got exactly the same thing going on with my '05 Tahoe. Have you had any response anywhere else to this problem????
Jeff
B
beav626
Usa
Jeff
yes- I replaced the resistor module next to the blower motor and everything worked great.
as long as you blower motor is working OK just not responding to controls I would replace the resistor module
its like $80 from partstaxi.com
HVAC Resistor module.
rv8tor
The resister module eh..? okay. Is it easy to get to?
Jeff
Chucktown Mako
Very easy. Under passenger side dash, on my '01 anyway. Remove long black cover, 3 screws, then you'll see it.
If it's different for your year, hope someone else chimes in.
B
beav626
Usa
my 03 EXT had 2 screws to remove the Sound insulator (Black plastic cover)
Then two screws held the resistor in place. I removed the blower motor to unplug the resistor. Blower motor just rotate out.
rv8tor
Thanks guys. I will give it a try and let you know how it goes..
Jeff
rv8tor
Okay, I replaced the module next to the fan, and now the fans blows. The only problem is that it blows on high 100% of the time, and the dash controls do not have any effect! What's even stranger is that even when I shut the engine down and take the keys out, the fan continues to blow. I have to unplug the power source from the car to the module to get it to stop so I don't run the battery down!
So what gives here? What am I missing?
Jeff
Tremendousslouch
