Hybrid Battery Reconditioning The Original 2009 battery
BG1988
I pulled the battery Didn't found any bad modules with low voltage..
Right now i'm cycling the modules individually
*Note: module #2 and #3 was charged in serial and rose in voltage so capacity on results may differ slightly.
(testing settings on how to work the charger) asetek symbol was added.
Update: looks like the battery had been messed with at some point in the past because of non oem markings only doing discharge (mAh)
initial Voltages shown below.
Charger settings
Discharge/Charge cycle
6.0V minimum voltage
Max voltage 9v
5min wait
Charge rate 3.0amps
Discharge rate 1.0amps
1. 7.6
*2. 7.5
*3. 7.5
4. 7.5
5. 7.5
6. 7.5
7. 7.5
8. 7.6
9. 7.5
10. 7.6
11. 7.5
12. 7.6
13. 7.5
14. 7.5
15. 7.5
16. 7.4
17. 7.4
18. 7.5
19. 7.5
20. 7.5
21. 7.5
22. 7.5
23. 7.5
24. 7.5
25. 7.5
26. 7.5
27. 7.5
28. 7.5
29. 7.5
30. 7.5
31. 7.5
32. 7.5
33. 7.5
34. 7.5
35. 7.6
36. 7.6
37. 7.5
38. 7.6
39. 7.5
40. 7.6
j91z28d1
one amp hour huh. new they are 7?
crazy how these trucks even start with such low capacity cells.
B
BG1988
the lowest cell so far was 7.5v to 6volt = 98mAh 1.50% of the original cell capacity of 6500mAh LOL
I have aggressively been attacking that cell with cycling it's at 900mah now..
the weirdest thing is the cells are not even getting warm or hot that is a good sign of low internal resistance
attaboyconllc2018
