I found water. Need to find from where.
992dr
Eastern N.C.
I was pulling out of my driveway and heard water falling, looked through my rear veiw and saw water dripping out from the molding right above the rear window/hatch. I pulled the panel off and it was full of water in the center part of the panel. I opened the rear up and saw a little mosture along the top of the weather stripping.
Does the top rear brake lite have a seal on it?
Is this a common problem? I have not had any issues with leaking before.
Any info would be much appreciated :)
Thanks guys:Handshake:
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Yes it has a seal. You should get it from a dealer.
---------- Post added at 05:09 PM ---------- Previous post was at 04:47 PM ----------
correction it looks to be a part of the center lamp itself perhaps some sealant under it will help if that is where it leaks.
992dr
992dr
Eastern N.C.
I may try to make a rubber gasket to go under the entire assembly.
That should work. I hope, hah.
b18cls1
