i have a 02 yukon drop problem
1slw4.8
Ok so i bought the 5inch spring did not put any thing else no shock extenders no drop shocks or any thing due to being lied to and at first it droved ok but now im stuck one of my springs popped out what can i do in order for it to stay in place?????? Help meeee!!!!!
1slw4.8
yes but now they told to install drop shocks and shock extenders and djm rear kit
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
1) you need the djm hardware kit
2) you will need the shorter shocks
I talked to you via text today. Before you do anything put the shock extenders in and then cut the bumpstop bracket off the frame so rides ok
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yeah its on stock shocks so even with extenders will pop out. I told him to try it with extenders in and when he lifts up the truck you will see the short spring will still pop out thats why with the 5 inch springs you need shorter shocks.
mitchell525
