Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
If you crawl up under the truck look for a Identification plate on the transfer case It should say NP (new Processes) and some numbers 241,243,246, ect. if the numbers match then yes it will .
My opinion , I think it will with no issues . I don't think 97s had Auto 4wd which would be the 246 auto trace
the trannys will swap regardless of the tcase number because the tcase is irrelevant between them for your purposes. the difference is in 1998 they changed tc setup. and bell housing. that is what requires some minor parts changes.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
