I need help with 03 yukon denali air ride!
mac11rideordie
Ok i checked fuses and did the jumper wire on relay and the compressor runs but doesnt come on when relay is in.... i went to lordco in my area and got a relay that matched but it had a extra pin in the center of the relay i just broke it off and tryed it and no difference now i dont know where else to look or maybe it still the relay i dont know but if you guys could help i am bit of a newbie!
You could try a reset on the autoride by removing the positive battery cable and then touching the cable to the negative battery terminal for a few seconds. I'd suggest getting the correct relay first- if the new one has an extra pin it could be completely different internally and you could damage other components. Relays are cheap, get the right one. The other system components are very expensive, hope you didn't damage anything. Good luck. Autoride problems are very challenging. I'm still trying to get the "service ride control" message off after completely replacing the system with Arnott stuff. At least it airs up now.
emfadz
