I need to adjust my headlights...
VTburban
Vermont
Can anyone help? NNBS Suburban...is it the inverted torx screw on the top of the assembly, on the upper-outside portion of the assembly? I need to lower both lights sumpthin fierce. Thanks!!
AZSCTACO
Phoenix, AZ
Have you tried using a star bit and turn it? Cause that's all you have to do.
vt_hokie2008
VA
Are they adjustable left/right? I've adjusted mine up and down as needed, but didn't see an adjustment screw for left/right
VTburban
VTburban
Vermont
Ok thanks guys, I'll try it tonight. I gave it about a half turn last night and didn't see any changes, but I'll spin it tonight and see what it gets me.
AZSCTACO
Phoenix, AZ
Park it facing your garage....put a piece of tape on the garage at the top of the light beam on the garage....it'll give you a reference point on how far your lowering.
VTburban
VTburban
Vermont
So mad. So the reason I'm adjusting my lights is because my local repair shop broke my oem housings when they removed them last time...they didn't unbolt the third bolt behind the wheel well. They replaced the housings, at "no cost," but I recently noticed that my passenger headlight was lighting up treetops as I drove. Not too pissed off at that point, so I spent the $3.00 on the torx head I needed and tried to adjust the light tonight as instructed. Turns out it doesn't need to be adjusted...the "technician" broke all three plastic clips on the bulb, so it's not seated properly. I've got light coming out the back of my headlight housing, making it clear that the bulb is just sitting on the rim of the housing. The a-hole who broke my housings last time was the same guy that jammed my bulbs in this time. So should I go down tomorrow during business hours and complain, or head out later tonight ninja-style and burn the place to the ground? AGGGHHHH!
DaisyGirl
