I seem to have fixed my code: P0171 P0174 issue...I guess
adrianb
Longview, WA
Hey gang – wanted to share my experience working through the P0171 and P0174 (too lean bank 1 and too lean bank 2) codes.
2003 Tahoe LT 5.3 flex fuel engine, 79,700, bone stock.
Background:
I was tinkering with the truck a few weeks ago trying to see if I could eek out any more MPGs and generally improve it’s health short of a tune up and well, I fixed it until it broke.
I started by adding half a bottle of Seafoam straight to the crankcase, and a few dosages of Lucas at fill-ups.
Couple weeks go by and I get the codes.
Clean the MAF and throttle body. Reset codes, they came back
Couldn’t find any vacuum leaks. Reset the codes they came back
Decide to change the oil ahead of service indicator. Used to a Penzoil synthetic. Reset the codes and….they stayed off.
This makes no sense so I continue with my campaign.
Last Wednesday, I cleaned the MAF again and change the PCV valve, have the fuel filter changed….still no codes.
I put probably 350 miles on the truck since Thursday and am still code free.
I can’t think of how it makes sense but it seems like everything got better after the oil change. Coincidence?
I hope this helps somebody else.
Tags for future searchers: P0171 P0174 too lean bank 1 too lean bank 2
91RS
GA
You need intake gaskets. Easy and cheap to replace.
Merc1973
Maryland
Figured I would bump this instead of cluttering and starting a new one.
I too have these problems with these 2 codes just after a long trip from MD to MI and back in the cold blast of winter. I experienced them after I got back and went through the enclosed touchless car wash. There was a lot of vapor/steam in the air since it was 10 degrees out, it began to idle pretty bad almost like it wanted to stall, I kept the RPMs up until the wash was finished. Idle was back to normal after being in the cold dry air.Its been starting just fine like it always does, even cold weather. Slight rough idle now since CEL came on. Comes back after clearing the codes.
I also noticed that when accelerating lightly when going above 2200-2400 RPM there is a slight hight pitched whistle just as it's about to change gears. It''s always done this. Sounds like the whistle in my 73 Cougar when I had a really bad carburetor gasket leak.
Suggestions? Intake gasket?
I will clean my MAF and try some carb cleaner around the intake gasket....
Scottydoggs
NJ
for the love of god, never put seafoam in the oil crank case. known to kill a engine or so. intake and gas tank only for that stuff.
HiHoeSilver
Away!
Chicago
I agree with this. I will, however put some Kreen in there every once in a while about 1000 miles before a change.
pipehand903
