Just00Jake
- Joined
- Jun 27, 2022
- Posts
- 67
- Reaction score
- 43
I started getting a random misfire code (P300) on my 2013 Tahoe LS 5.3. It then turned into a misfire on cylinder #2 (P302). I changed all the plugs and wires figuring it was probably due for a tune-up. Of coarse I bought OEM Delco Irridium plugs and good wires. No change, so I paid a "mechanic" to run diagnostics on it. I was told that I needed a new coil pack for #2, so I replaced them all, no change. I had it checked for vacuum leaks and none were appearant. So I asked what it could be? I was told that it must be a broken valve spring, without compression I'd get a misfire code. I picked up a compression tester and actually got compression on my #2 cylinder. I am not sure how many times it cranked but the gauge read 90psi. My question is if I had a broken spring causing a misfire, wouldn't that mean that one of my valves would always be open? Wouldn't that prevent me from registering any compression or am I totally nuts? I hope I am nuts because if the spring isn't broken then it's gonna drive me nuts trying to figure out what to try next. This all started with an intermittent rough idle 2 months ago. I appreciate any help. Thank you
