dblover1327
Hey All. Haven't been a while on the forums but trying to get back to working on my tahoe. I ended up moving back to colorado and wanna install remote start since my last car had it and was great to have in the winter time. Question is I bought a idata link multi ADS-DL bypass modular and about to get the viper 5704. Question is for the install part so I get this right,on the idatalink, you only need the far right connector which has the data(0range) and ignition cable (pink) cables. Connect the data to the data connector pin 2 on the OBDII Connector and ignition goes to the ignition of the viper 5704 ignition, which then goes to the ignition harness on the tahoe which is pink. Then on the 5704 I need to connect the parking light which is brown (driver kick panel), ignition 2 wire from the 5704 to the white wire on ignition harness, all power and ground cables on the 5704, and then accessory on the 5704 to orange wire on ignition harness. Then the data link cable connects from the viper to the idatalink modular. If I am missing anything else please let me know. O if somebody did the window up and down modular, how hard is that to install to. I installed my last alarm but this is a newer car (my old one was a easier to install). I don't wanna take it to the shop since I had an issue before with an installer and rather do it myself and try it out. Thanks
