ignition issue -- lights won't come on, but cranks
Wing Bucket
Had an issue come up, wondering if you have any ideas....
Normally, when you insert the key and turn the ignition forward, you hear a couple clicks, the warning lights come on for a second, the gear indicator and 4x4 indicator light up, and you hear a 4-5 second beep.
The issue: I turn the key forward, but there's no beep and the warning lights don't come on. If I turn it further to start, it just cranks over but doesn't start [which is odd, because when it's working properly, you don't even hear it crank, it just fires right up].
The gear indicator and 4x4 indicator do light up, but no other lights and no beep.
Sometimes I can jiggle the key or move the shifter into gear and back to park, and that makes the lights and beep come on. Then I can start.... But that doesn't always work.
The "Security" light doesn't come on, so it doesn't seem light this Passlock sensor issue I keep reading about. But it does seem like some kind of sensor issue.
Any ideas? Thanks!
BigWheelinBubba
Troy, MI
Manual Lever Position Sensor on the side of the transmission is out of adjustment or your shift linkage is worn and needs to be repaired.
Wing Bucket
Wing Bucket
Thanks for the quick reply.
The transmission shop in town thought if the sensor wasn't working right it wouldn't be able to shift from park. They referred me to a couple general auto repair shops in town.
I found some info online about how to adjust the MLPS, but looks like I'd need a special tool to do it.
Any other ideas on how to diagnose? Maybe it does have to do with this Passlock thing....
zomeizter
North AL
PRNDL switch only prevents starter operation other than N or P positions, sounds more like your ignition switch is failing.
Wing Bucket
Wing Bucket
Thought I'd provide an update. Since I know you all have been on the edge of your seat....:gr_grin:
First tried replacing the **** fuses. No luck there, problem still occurred.
Problem happened more and more frequently. Went ahead and replaced ignition switch, and that fixed it! Got new AC Delco switch online for $120 shipped.
Anyway, appears to be resolved. Glad to not be sitting in a hardware store parking lot fighting this anymore!
Dozer01
