Info on Belltech 2/4 drop on 2013 Tahoe
HBTahoeSS
Ordered a 2013 Tahoe LTZ with the self leveling and want to drop it on 22s. Looking for those with a Belltech kit for info on ride, self leveling issues, bounce, bottom out issues, etc. What do you do with the self leveling? When lowering what does the self leveling still work? Any recommendations? Thanks!
Chad
baggedlvintegra
Fort Worth, TX
I'm in a similar boat, TONS of info in this section. Just spend some time reading through threads and you can piece it together. Tony (NorcallSS) is the best place to get the Belltech kit from and has EXCELLENT 24/7 customer service
H
HBTahoeSS
So the front uses the OE springs with the Belltech drop spindles? Anyone done the larger Belltech swaybar?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
H
HBTahoeSS
Sorry, I'm a bit confused. I'd like to add the bigger sway bars to the LTZ w/ autoride. Do I need to add the shocks also? I HATE the check engine light issue, how do I get the best handeling w/o the light? I'm in California, so disconnecting the light is out of the question with smog checks. If the light is disconnected or on constantly they won't even test the truck for smog. Any ideas? Also the one link you posted says it's for trucks w/o autoride.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Thanks. Its easier to sell kits if you actually have used and installed them in trucks and not just reading out of parts books.
gordo214ace
