Installed OPT7 LED headlights.
shaky
They are bright but little more depth and focus is needed. Work fine as lowbeam headlight but my DRL dont work with these.
d3laan
Can you tell us more information about the product and how you install it
02Greenz71
Are they the FluxBeam LED or the FluxBeamX LED? I'm going to be doing my low beam and fog lights in the near future. The FluxBeam says it puts out 3500 lumens per bulb, and the newer FluxBeam X is suppose to put out 4209 lumens per bulb. I figure with low beam and fogs together I wouldn't need high beams...
S
shaky
Hi sorry for late reply...
They are the FluxBeam X version... They are bright and look good BUT i think they lack the depth after 15 to 20 feet ahead. I dont know how they are for out of town highways/roads which are dark... i do city driving mostly but sometimes go out of state.
when i took those pic it was just a little foggy... so they appear very bright . The color is little bluer tint. like 65000 k ... i like 5000 k better.
S
shaky
Shaky,
What do you mean your DRL's don't work with these?
Its like when its day time the low wattage drl which uses low beam bulbs does not come on. ( that yellow dim light ).
They only come on when its dark outside with full wattage.
S
shaky
About the Beam pattern... In the last pic you can clearly see ( because of fog ) the beam pattern pretty strong coming out of headlights and then disappearing fast.
memakos
