Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Anyone who has installed a leveling kit. How hard is it. Any special tools needed any tricks that worked well? I have mine in my garage and am going to try to install next week. Just wanted a heads up on any problems I might have.
Just ordered the ccm kit today! Those of you who have installed already, are there any special tools that are needed besides the metric stuff....floor jacks..etc?
Def need 2 people. Sawzall to cut the strut bolt tips, or you could use a hacksaw but it would take a while. I didnt do the rear myself but the guy who did it for me said it was kind of a pain. I couldnt get the rear high enough to get the spring out, might want to try a spring compressor but Im not sure if that helps.
No you have to cut the top of the strut studs for the 2 1/2" spacer to fit over the top of the strut. The strut studs are about 3" tall which means the 2 1/2" will now fit. You can buy a hacksaw cheap at any hardware store, I also used a lubricant so it did not heat up and damage the blade but you dant have to.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
