Installing ACDelco 15-74023 OE Service HVAC Control Panel
LTLux
I have and it works fine. The only thing you have to do is take it to a dealer to get flashed, if not it will not run the AC corectly.
Do a search on it and you will find a long post by me in order to figure out my problem.
I guess I should mention that you need to have a automatic climate control already installed. If you have a manual, I don't think it will work.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
If yours is manual, this will NOT work for you. There are other pieces you will have to purchase as well as the correct control modules and replace the entire wiring harness...
Modded
That Guy
To add on to what Yates posted, basically, it won't work.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
DAMMIT I'M NOT YATES!!!!!!!!!!!!!!
:lol2:
:hands:
Different names, different avatar, different color vehicle, COMPLETELY different upgrades/customizations...
NathanJax
Vacation Nathan
Administrator
Jax, Fl
What other things does it need, Nathan?
I've never seen it done because of all the stuff you have to change. You have to get the temperature sensor, the entire inside wiring harness, have to get your BCM reprogrammed (or new BCM) You'd have to get the aspirator fan thats just above the driver in the headliner, cut our current headliner and place that in...
it's just too much.
kenmatthewclark
