Instrument cluster questions.
justsethpc
So I would like to change out the lights behind my cluster, is it regular bulbs that can be replaced by LEDs? If I get different color LEDs, do I have to change out the cluster face? If yes, anyone know where I can get a PPV cluster face and NOT a regular one? Ultimately, I would like to change the colors to straight white or even a purple or blue as a last resort.
**FYI** yes, I searched the forums but can only find vague information about the civilian clusters not the PPV ones. Figured I would say that before someone tells me to search.
mikez71
@Doubeleive Did you change your dash lights?
AFAIK the PPV cluster goes to 140mph, but I doubt much else is different other than the overlay.
Sorry I don't know where to get them.
BTW I now see speedometer scaling adjustment in the BTDieselworks' AutoSync BCM tuning..
Anyone ever swap a PPV speedo in a non-PPV? I wonder if the speedo scaling is in the BCM or the speedo itself.
I purchased a brand new ppv cluster back in like 2018, I provided my vin, mileage, hours and it arrived ready to plug n play, I then had a local guy install leds, changed the needles and I also purchased the white overlay from basically the only place that makes them or at least they were when I ordered mine
I do not know about the scaling, it works I have buried it at 140+. other than the marker design and speed I do not see any differences it doesn't work any different other than going to 140. there are no "secret" or "special" ppv things involved as some may be led to believe
J
justsethpc
Yeah I figured there isn't anything special other then the 140mph part. In the 3rd gens are they soldered leds or regular bulbs?
Lukekuhner369
