I recently installed a pair of genuine made-in-china taillights in my 2001 Yukon XL. These units had load resistors on the turn signals but nothing on the brake or parking lights. The lights worked fine and I am satisfied with them in that respect. However, I discovered that my cruise control no longer worked so I ordered a set of plug-and-play (wired with connectors) resistors which had a 6 Ohm/50 Watt resistor for the brake lights and one for the parking lights. After some tribulation with blown diodes and circuit wiring all worked and the cruise control also worked. However, now My instrument cluster and radio cluster lights go out when I step on the brake. There may be other issues as well but they have not surfaced yet as I just discovered this today as I was shifting out of Park and the gear indicator went black. As soon as I released the brake it came back on. The Service Engine Soon light was unaffected (its on because of crapped knock sensors, or at least their indication as there is no knocking from the engine).
If anyone has any clue at all why this is happening I'd very much appreciate your insight, its driving me nuts.
An update on this issue: Last night I checked to see what happened when the headlights/parking lights were on with the result that the instrument lighting worked fine. With the low light level with the headlights off I could see that the cluster lights were not off entirely but very dim, too dim to be seen in daylight. Hope this helps some.
Thanks,
Andy
Thanks,
Andy
