Interior Lights
UGA Tahoe
Jacksonville, Fl
Just wanted see if anybody is having the same problem before I decide and go to the dealership. My interior lights and headlights automatically come on everytime a turn on the truck and they never turn off. I can manually turn the headlights off but the interior lights still stay on. It is really annoying and it is starting to burn some bulbs in certain areas. Any help would be great.
Thanks
toneman
Thanks
Okay you probably already checked this but then again, sometimes the most obvious things can be overlooked--did you check if the dimmer switch (actually it's more of a wheel rather than a button or rocker switch) is stuck in the all-on position? There is a slight detent where if you push the wheel upwards past the "brightest" position will enable the interior lights to remain on.
UGA Tahoe
UGA Tahoe
Jacksonville, Fl
Yeah I checked this. I think I am going to just take it to the dealership and have it checked out. Probably has to do with some kind of sensor. Hopefully nothing to expensive or crazy.
bigtoe
