Ok 02 tahoe 134,000 miles. No real set timing or reasoning for this whining that im hearing, it wont do it all the time and it comes and goes. Doesnt change with steering, and goes away after rpms come up just to around 2000, sometimes comes back, sometimes not, most noticeable at idle. Volt gauge reads around 15 volts all the time, doesnt change with accessories or speed, and gauge doesnt change when noise occurs. Anybody had this happen? It has new belts, but quite sure pulleys are factory. When it occurs, I can put my hand on the alternator and "feel" the noise coming from it. Is it possible to have an intermittent noise like this from failing bearings in pulleys, etc., or from a failing alt., with no other symptoms? I am not into just throwing parts at it, so thought this might be the place for some good info. Thanks
